Personal address book + Personal fast Dials CCM 7
Mar 22nd, 2009
I have CCM ver 7 , I need the steps to do personal address book and personal fast dials in CCM ver 7
thank and regards
craiglcve Sun, 03/22/2009 - 14:11
These services are built in now. You do not need to add these services manually. You will find them by pressing the 'Directories' button on the phone and then 'Personal Directory'. You will need to login with a valid user and you will see those services.
uniccnp Mon, 03/23/2009 - 00:51
firstly thank you for your corporation
well, if the customer or user wants to add his/her numbers in address book or add fast dials in his own phone how ???
thans man
craiglcve Mon, 03/23/2009 - 10:08
Basic steps are:
Configure Phone
Configure End User
Set the End User PIN
Associate End User to the Phone
Add End User to the End User Group
After the end user is associated to the phone with a pin set they should be able to either login to the user page or login to the personal directories on the phone.
The web page is
http://X.X.X.X/ccmuser
