Prefix 9 for outside numbers- CUCM 6.1.3
Pardon me, but I inherited this system recently when the installer vacated - this was an internal install.
The managers would like to send out every call that has 7 digits to the PSTN - Verizon SIP trunk through CUBE by prepending it (they forget to put a 9 in front and area code not required).
Is this possible?
Thanks! And this place is an AWESOME resource!!!
Overall Rating: 5 (1 ratings)
shane.orr Sun, 03/22/2009 - 20:34
So I am assuming you have Call Manager. If so it is possible for a route pattern to allow 7 digit dialing without an access code but typically I dont like to do this because inevitably it will overlap with internal extensions and other system DN's and you will experience inter-digit timeout problems. But if you are comfortable with that caveat you can just create a [2-8]XXXXXX Route Pattern with no digit manipulation instead of something like 9.[2-8]XXXXXX PreDot or have both.
Again let me emphasize te that this is something I typically push back on if asked.
