EIGRP question
To all,
I have a minor issue. Is there a way to weight a route within EIGRP.
SiteWIN - VPN (192.168.101.x) - CORP
SiteWIN - PTP t-1 (10.103.1.x) - SiteMSP
SiteMSP - MPLS t-1 (172.20.x.x) - CORP
SiteMSP - PTP t-1 (10.103.1.x) - SiteWIN
Right now, EIGRP uses the PTP to another branch office (SiteMSP) as the primary route and will failover to VPN if the s1/0 goes down. I want to weight the 192.168.101.x route as the primary and failover to the PTP if the VPN goes down. Is there a way to do this? I have included a sanitized version of my config.
My guess is I am going to have to use SLA w/ static routes but would like a second opinion...
Any inut would be greatly appreciated!
!IOS 12.4.18 AdvSec
!WIN-config sanitized
version 12.4
hostname WIN-1760
ip cef
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key somekey address 207.x.x.x
crypto ipsec transform-set myset esp-aes 256 esp-sha-hmac
crypto map myset 10 ipsec-isakmp
set peer 207.x.x.x
set transform-set myset
match address 101
interface Tunnel0
description GRE to CORP
ip address 192.168.101.2 255.255.255.252
no ip redirects
no ip unreachables
ip nbar protocol-discovery
ip route-cache flow
ip tcp adjust-mss 1436
tunnel source Ethernet0/0
tunnel destination 10.99.1.1
interface Null0
no ip unreachables
interface Ethernet0/0
ip address 69.x.x.1 255.255.255.252
ip access-group 103 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
ip inspect standard out
ip route-cache flow
full-duplex
crypto map myset
interface FastEthernet0/0
description WIN LAN
ip address 10.101.2.1 255.255.255.0
ip access-group 102 in
ip helper-address 10.1.1.104
no ip redirects
no ip unreachables
ip route-cache flow
speed auto
interface Serial1/0
description WIN_PTP_MSP
ip address 10.103.1.1 255.255.255.252
no ip redirects
no ip unreachables
ip route-cache flow
router eigrp 333
passive-interface Ethernet0/0
network 10.0.0.0
network 192.168.101.0 0.0.0.3
no auto-summary
ip forward-protocol nd
ip route 10.99.0.0 255.255.0.0 69.x.x.2
ip route 207.x.x.x 255.255.255.0 69.x.x.2
Richard Burts Sun, 03/22/2009 - 18:49
Mark
I believe that there is a solution that is much less complex than implementing IP SLA and static routes. You can configure an offset list under EIGRP which will add an amount to the metric for the route through the PTP T1 and make it less desirable than the route through the VPN, which is essentially a solution to weight the route within EIGRP.
In its simple form you might configure something like this under router eigrp:
offset-list 0 in serial1/0
and it would add the to the metric of all routes learned over serial1/0. You might need to experiment a bit to find the value that you need to add that is sufficient to make the routes less favorable. If you need to influence only certain EIGRP routes there is a version of the offset list that uses an access list to identify the prefixes to which you add the value:
offset-list 50 in serial1/0
where access list 50 identifies the prefixes to which you will add the value.
Give it a try and let us know how it works.
Rick
