Factory Reset for AP 1010
dennischolmes Mon, 03/23/2009 - 07:01
  • Gold, 750 points or more
My first post didnt show up so here we go again. The 1010 has a 2 pin console port inside of it to do a lwapp config to default factory reset. You open it up with a terminal session. This requires a special cable as well. The easiest way will be to get a spare controller and set the interfaces to be on the same network as the AP. Once it joins, reset the AP to factory defaults and reboot it. Make sure it comes back up then simply change it from static to dhcp and join it to the new network and controller via dhcp. Make sure all versions of code support the 1000 series APs.
dennischolmes Wed, 03/25/2009 - 07:59
I got mine from Airespace and have no clues as to which pins were pinned out on it. I haven't seen it in 2 years or I would open it up and look. It is a serial 9 pin to a small 2 pin connector.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
