MOH audio source (file) at device pool level.
Mar 23rd, 2009
Administration guide says this; the system selects audio source IDs that are defined in level two, which is DevicePool-based.
I don't see it in device pool configuration page.
Appreciate your help
James Hawkins Mon, 03/23/2009 - 03:59
  • Gold, 750 points or more
In later versions of CUCM MoH has moved from the device pool to (I think) the Common Device Configuration profile which is accessible under the Devices menu option.
