LMS3.0 Daemon Manager Fails to start
After LMS3.0 installation, i did integration with ACS4.2 for TACACS,but when I restart the system daemon manager service fails to start up again and all services fail. I reboot the box with the same problem, Daemon services fails to start. I've tried to run the resetloginmodule.pl and even reinstalled lms3.0 but same issue persists
MICHEL.HEGERAAT Mon, 03/23/2009 - 05:51
Failure to start daemon manager are usualy caused by permission problems.
Check if casuser is the owner of all ciscoworks files
Cheers,
Michel
David Stanford Mon, 03/23/2009 - 05:59
  • Cisco Employee,
What error do you get when you try to start the daemons? Any errors related in the syslog.log?
Could be casuser acct settings on windows. Try resetCasuser.exe and generate a random pwd or enter a password that meets your criteria.
Then try to start the daemons.
after resetcasuser, daemon manager started successfully but DCR server+License server was still down & process management window didnt open it hung.now i am re-installing it again.Apart from this issue i want to know if a single standalone lms server be used to manage different devices in different location under different admins without integration with ACS,assume my company has office at 3 diff. places & lms is just installed at 1 location but there are diff. admins at 3 locations, so can they be able to manage only devices in their regions & not others with adding devices in ACS
