inspect http
Mar 23rd, 2009
Hello!
I am confused, ASA with inspect or without inspect.
A simple schema
100 0
http client------ASA--------http server
inside out
100 0
http server------ASA-------http client
inside out
What should I add to the first and second circuits to allow the client access to server and please explain why?
Thank you very much!
smalkeric Fri, 03/27/2009 - 08:38
When you enable "inspect http" command in ASA it protects against specific attacks and other threats that may be associated with HTTP traffic. HTTP inspection performs enhanced HTTP inspection.
You must apply ACLs to an interface to allow the passing of traffic on an interface. You can apply one ACL of each type (extended and EtherType) to both directions of the interface. For connectionless protocols, you need to apply the ACL to the source and destination interfaces if you want traffic to pass in both directions. For example, you can allow BGP in an ACL in transparent mode, but you need to apply the ACL to both interfaces.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094ea2.shtml
