Not able to enter Rommon mode with Cisco 870 series
Mar 23rd, 2009
Hi All,
I'm trying to enter Rommon mode on a Cisco 870 series Router. This is to recover a corrupt IOS image.
Basically when I send Break during boot, it just cycles the System Bootstrap instead of entering Rommon mode.
I am using TeraTerm and sending Alt + B. I've also tried with HyperTerminal and sent CTL + B, but get the same outcome.
Does anybody know if the procedure is different on 800 series routers? It doesn't appear so from looking at other bits of info.
See below for the output whilst booting:
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
Booting flash:/c870-advsecurityk9-mz.124-15.XY3.bin
'Here is where I sent the Break, which causes Bootstrap reload'
Error : compressed image checksum is incorrect 0x4DCCADCB
Expected a checksum of 0x8F526C45
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
PC = 0x0, Vector = 0x0, SP = 0x0
TIA
Kevin
Overall Rating: 5 (1 ratings)
falain Wed, 03/25/2009 - 08:38
on Teraterm, how do you send a ctrl-Break ?
I only know that Break is sent with Alt D but it doesn't work
falain Wed, 03/25/2009 - 12:14
I know the Ctrl Key but the Break key doesnt exist !
On Teraterm, you must press Alt B to send a break
and Ctrl Alt B doesnt work
a.alekseev Wed, 03/25/2009 - 12:21
power off
connect a console cable
set speed in terminal - 300
power on
wait 1 minute
change speed in terminal to 9600
you should be in rommon
falain Wed, 03/25/2009 - 08:42
Sorry, I would say Alt B not Alt D
falain Wed, 03/25/2009 - 08:34
I just have the same pb with a Cisco 857
If I send a break (Alt-D with Teraterm), it reboots but when I leave it cooting, I have:
C850 series (Board ID: 2-149) platform with 65536 Kbytes of main memory
Booting flash:/c850-advsecurityk9-mz.124-15.T3.bin
Error : compressed image checksum is incorrect 0x972A2B28
Expected a checksum of 0xC6EA1672
Don't what to do
falain Wed, 03/25/2009 - 10:26
I just said that I cannot issue anything
I can't break boot sequence
kgreenway Wed, 03/25/2009 - 12:44
I found my problem in the end.
Cannot remember the exact article on Cisco website but a command had been applied which prohibitied me from entering Rommon. Removing the flash completely erased config, etc which was blocking me in the 1st place.
Powered off the Router, removed the Flash, powered up the Router. Router failed to boot without flash, but I was able to enter rommon mode.
Powered off, reinserted Flash. Powered up, Entered Break during boot and straight into Rommon. I was then able to recover IOS using tftdnld.
Hope this helps you too.
Kevin
Leo Laohoo Wed, 03/25/2009 - 15:31
Hi Kevin,
This will work if your appliance has a removable compact flash. The problem is the 870 router doesn't have this luxury.
Leo Laohoo Wed, 03/25/2009 - 15:32
Hi Kevin,
