7975 Phone and (2) 7916 Expansion Modules only 42 buttons
Mar 23rd, 2009
I have a 7975 phone with (2) 7916 Expansion modules. The modules are 12 buttons each, both with 2 pages making them 24 buttons each. There should be 48 total expansion buttons and 8 on the phone making it 56 for the entire setup. Callmanager only shows 42 buttons total (counting the ones on the phone also) allowing me to only use the first 10 buttons on the first page of the second expansion module. I was running version version 7.0.1.11000-2. TAC had me update to 7.0.1.21007-1 saying this was a known bug and it would resolve it. After the update the problem still exists. A few days later TAC finally gets back saying this is "normal operation" for this version and that I have to wait for the next release. Sounds like I am getting jerked around on this. Anyone experience the same issue and get it resolved?
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 03/23/2009 - 06:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Steve,
Here are the details for this issue. This has not been fixed in any current 7.x versions.
Cisco Unified Communications Manager 4.2(3)SR3a, 4.3(2), 5.1(3)b, and 6.1(1), 7.0 and 7.1
Total Number of Buttons Supported
Cisco Unified IP Phone 7975G = 42
Future Cisco Unified Communications Manager Releases
Cisco Unified IP Phone 7975G = 54
Cisco Unified Communications Manager Express 4.3 and later
Cisco Unified IP Phone 7975G = 56
From this 7916 Data Sheet;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468673.html
I believe you are hitting this bug which has only been fixed in certain 6.1(3) versions;
CSCsx47243
CUCM 6.1.3 Phone Button Template for 7965/7975 Shows 34/36 line.
Symptom:
On CUCM version if you have a 2 7916 extension moduleon7965 and 7975 the Phone Button template is not capable of 42 lines as per Document we can only ad 34/36 respectively.
Conditions:
When you want to add the 2 7916 extension modules to the Ip phone 7965 /7975 Phones we can not make 42 line Phone Button template for those Phones.
Workaround:
No Work around
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Cisco Unified IP Phones 7900 Series
Technology
1st Found-In
6.1(3)
Fixed-In
6.1(3.2101.1)
Hope this helps!
Rob
Sushil Kumar Katre Mon, 03/23/2009 - 21:32
  • Gold, 750 points or more
Hey Rob, thanks for sharing this info (+5). Somehow I was not aware of this.
-> Sushil
Rob Huffman Tue, 03/24/2009 - 07:09
  • Hall of Fame,
    Founding Member
Hey Sushil,
You are most welcome buddy! Thanks for the nice vote. This is a weird one, that's for sure ;-)
Cheers!
Rob
