call flow/dial peer help
Mar 23rd, 2009
  • Bronze, 100 points or more
sorry for all the double posts. thank the apache error that is killing me.
So help me understand this call flow.
I have an analog line on an FXO coming in with a connection plar opx statement.
The call comes in, hits the port and heads off to the plar extension.
Voip dial peer picks it up and it goes to call manager then just rings and rings.
voice-port 0/0/1
trunk-group POTS_OUT
timeouts call-disconnect 3
timing hookflash-out 50
connection plar opx 82011114
description 7409482562
caller-id enable
dial-peer voice 42 voip
service mgcpapp
destination-pattern .
session target dns:callmanager
codec g726r32
dial-peer voice 82011114 voip
destination-pattern 82011114
session target ipv4:10.60.200.25
dial-peer voice 999001 pots
port 0/0/1
and heres a debug
Mar 23 13:42:48.277: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
Mar 23 13:42:48.277: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=42
Mar 23 13:42:48.281: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=82011114, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=82011114
Mar 23 13:42:48.281: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=82011114, Expanded String=82011114, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 23 13:42:48.281: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=42 Is Matched
Result=Success(0); Outgoing Dial-peer=82011114 Is Matched
Mar 23 13:42:48.281: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=82011114
2: Dial-peer Tag=42
Mar 23 13:42:58.333: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=7404639515, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=7404639515
Mar 23 13:42:58.333: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=7404639515, Expanded String=7404639515, Calling Number=
Mar 23 13:42:58.333: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Mar 23 13:42:58.333: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=42
Result=SUCCESS(0)
2: Dial-peer Tag=42
JEF_CR_R01#
Nicholas Matthews Mon, 03/23/2009 - 19:57
  • Red, 2250 points or more
You've got it backwards:
port 0/0/1
service mgcpapp
dial-peer voice 42
default service
hth,
nick
