03-23-2009 06:58 AM - edited 03-06-2019 04:45 AM
Hello Sir's,
I just want to ask on what is the consequences of running two EIGRP process in a Router. Appreciate your help
Jong
Solved! Go to Solution.
03-23-2009 07:57 AM
can you tell me , if I run 2 different eigrp processes, and some have the same routes in them, what would happen, would it use the route with the lower eigrp process number ?
03-23-2009 07:30 AM
More memory utilization, more CPU utilization...
Depending on the topology and your requirements, it may or may not be necessary.
You havent really provided us with any information to make a qualitative judgement on the efficacy of running 2 eigrp processes on the same router.
Victor
03-23-2009 07:57 AM
Jong
When you run 2 EIGRP processes each process maintains its own topology table. So Victor is correct that there is some increase in memory utilization (but not much if the same routes were learned in a single process).
With 2 EIGRP processes the IP routing table will show the best routes learned by either process. They will look the same in the routing table, but routes learned in one process will be advertised only to neighbors learned through that process and not to neighbors learned through the other process. So there may be EIGRP routes in the routing table that are not advertised to some of the neighbors. This could be a good thing if you had a requirement to route for 2 domains (perhaps 2 divisions within an enterprise) but not to share routes between the domains.
Rick
03-23-2009 07:57 AM
