7965G "Display on time" CUCME
Answered Question
Mar 23rd, 2009
Is there a way to configure the "Display on time" and "Display on duration" settings in CUCM Express? I can not change the settings from the phone display, nor can I find any CLI reference.
Thank you in advance for your help.
Correct Answer by Rob Huffman about 8 years 2 months ago
Hi Jack,
These settings are found here;
service phone
To modify the vendorConfig parameters in the configuration file, use the service phone command in telephony-service or ephone-template configuration mode. To disable a setting, use the no form of this command.
service phone parameter-name parameter-value
no service phone parameter-name parameter-value
For example
displayOnTime HH:MM
Sets the time of day at which IP phone displays are activated, using a 24-hour time format.
•Hour (HH) and minute (MM). You must enter all four characters. For example, 9:05 a.m. must be entered as 09:05. Default is 07:30.
Note This parameter is not supported in ephone-template configuration mode.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1092998
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 03/23/2009 - 07:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jack,
service phone
For example
displayOnTime HH:MM
Hope this helps!
Rob
