Transfer Call Drop
Mar 23rd, 2009
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
My Customer have any directory number that is with following problem: When A receive the call external and try transfer B, the call drop. The same problem occur when a one call is did internal. I verify the CSS and didn't found problem.
Wilson Santana
wilsonsant Mon, 03/23/2009 - 13:17
It is a CallManaer 5.1
Wilson Santana
Hythim Ali El Hadad Mon, 03/23/2009 - 13:09
  • Silver, 250 points or more
Hi Wilson,
In most cases
it is a codec mismatch problem
Please check if there is a transcoder exist in your MRGL
Or you have the 3-ip phones using the same codec [ in the same regon ]
awaiting your feed back
wilsonsant Mon, 03/23/2009 - 13:20
I Verify the configuration and it correct. My Customer didn't nothing change in the network. The problem is occuring randomly.
Wilson Santana
lordshawn Wed, 04/01/2009 - 08:44
Collect the traces, open them up and do a search on "Mediaresource" See if you have any allocation errors.
wilsonsant Wed, 04/01/2009 - 10:02
Thank You for your collaboration. I will verify this possibility, but,I don't believe that the problem is lack of resource, because, the Customer have many bandwidth available. The Regions is configuring all sites with G.711
Wilson
