Which is the most dominant igp in industry?
Answered Question
Mar 23rd, 2009
  • Bronze, 100 points or more
Hi everybody!
Which igp is widely used in industry?
thanks a lot!
Correct Answer by Joseph W. Doherty about 8 years 5 days ago
"In a purely Cisco environment from my experience it's pretty much 50/50 as to OSPF/EIGRP.
Zeeshan, if you're wondering why a pure Cisco network might run OSPF rather than EIGRP, it also avoids being locked into a proprietary routing protocol. You always have the option of using Brand X.
Correct Answer by Giuseppe Larosa about 8 years 5 days ago
Hello John,
before the introduction of EIGRP stub feature scalability of EIGRP was an issue.
Limiting the query range is the key point for EIGRP scalability.
I agree with Edison : EIGRP is not regarded as scalable as OSPF in large networks.
Note: Being multivendor ready can be a customer requirement or a wise suggestion
for a consultant.
Hope to help
Giuseppe
Correct Answer by Jon Marshall about 8 years 5 days ago
Sarah
Think it really depends on the environment.
In a mixed environment (mixed in terms of vendor) then OSPF.
Jon
Correct Answer by Edison Ortiz about 8 years 5 days ago
OSPF - open standards.
EIGRP isn't used as much since it's Cisco proprietary and RIP is pretty much dead.
ISIS is used within some large enterprises and service providers but not by much.
HTH,
__
Edison.
Correct Answer by John Blakley about 8 years 5 days ago
I would have to say EIGRP or OSPF. I think EIGRP is more dominating though.
HTH,
John
Overall Rating: 5 (7 ratings)
Correct Answer
John Blakley Mon, 03/23/2009 - 07:48
  • Purple, 4500 points or more
HTH,
John
Correct Answer
Edison Ortiz Mon, 03/23/2009 - 07:49
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
John Blakley Mon, 03/23/2009 - 07:53
Edison,
"EIGRP isn't used as much since it's Cisco proprietary..."
I agree any interaction between Cisco devices and non-Cisco couldn't use EIGRP, but would you still hold the same notion that OSPF is a bigger player if all Cisco equipment is used?
I would figure that the ease of setting EIGRP up as compared to OSPF would make it a more reasonable choice.
John
Edison Ortiz Mon, 03/23/2009 - 07:56
  • Hall of Fame,
    Founding Member
Yes
Both protocols have their pros and cons but many find OSPF easier to manage in large deployments.
__
Edison.
Correct Answer
Giuseppe Larosa Mon, 03/23/2009 - 09:27
  • Hall of Fame,
    Founding Member
Hello John,
for a consultant.
Hope to help
Giuseppe
Correct Answer
Jon Marshall Mon, 03/23/2009 - 07:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sarah
Jon
Correct Answer
Joseph W. Doherty Mon, 03/23/2009 - 09:30
Jon Marshall Tue, 03/24/2009 - 14:33
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
One other point worth making. Within the campus environment Cisco themselves recommend using EIGRP with summarisation over OSPF for faster convergence in a high availability environment. OSPF has throttles for both LSA generation and the SPF calculation and these can increase convergence times over EIGRP significantly.
Certainly in the UK BT is one of the major MPLS providers and they are, or at least were at the time, in favour of using BGP to peer from customer sites to their PE devices. This being the case each site ends up with it's own EIGRP AS that is not connected to any other EIGRP AS.
Also OSPF is a more complex protocol and does not necessarily map as easily into a campus environment.
So with the advent of MPLS and at least in the area i work in which involves the use of BGP to peer to MPLS WAN, EIGRP is a quite a sound choice.
Jon
