Access-List To Block Port
Answered Question
Mar 23rd, 2009
All,
I want to block ports 445 and 135 on the router going to a specific host. Will this access list yield those results if I put this access list on the router's inbound interface:
access-list deny tcp any host 11.1.5.0 0.0.0.255 eq 135
Correct Answer by dario.didio about 8 years 4 months ago
the syntax of you access list is not correct. You should specify a host address after the word HOST instead of a subnet. Also, don't forget to give your ACL a name or number.
Also, this line will only block TCP to port 135, not to 445.
If your host is 11.1.5.1, your ACL will look like this:
access-list 100 deny tcp any host 11.1.5.1 eq 135
access-list 100 deny tcp any host 11.1.5.1 eq 445
access-list 100 permit ip any any
HTH,
Dario
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 03/23/2009 - 08:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mario
It depends on where the 11.1.5.x hosts is in relation to router interfaces. By the way 11.1.5.0 0.0.0.255 is the /24 network and not a host as such.
11.1.5.0/24 -> fa0/0 R1 fa0/1 -> any
So in the above 11.1.5.0/24 is connected to the fa0/0 interface of R1. And all other addresses come in via fa0/1 so you would apply your access-list inbound to fa0/1.
Jon
mrashby Mon, 03/23/2009 - 08:49
Jon,
Does it matter if I apply this list on the inbound interface of the ethernet or serial?
Jon Marshall Mon, 03/23/2009 - 08:53
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes it does. Looking back at the digram in my last post you can either
1) apply it inbound on the fa0/1 inteface
or
2) apply it outbound on the fa0/0 interface.
Personally i would go with 1).
Note i have used fast ethernet interfaces as example but the same applies to serial interfaces.
Jon
Correct Answer
dario.didio Mon, 03/23/2009 - 08:25
  • Silver, 250 points or more
HTH,
Dario
