Problems with openLogicalChannel
Mar 23rd, 2009
Hello:
I want to do a videoconference between two endpoints through a gw. I choose 128 Kbps, and I have only the audio. The GK admits the call for the gw but in the openLogicalChannel phase I have this:
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
forwardLogicalChannelNumber 3
forwardLogicalChannelParameters
dataType videoData : h263VideoCapability :
qcifMPI 1
cifMPI 1
cif4MPI 2
maxBitRate 3360
unrestrictedVector FALSE
arithmeticCoding FALSE
advancedPrediction TRUE
pbFrames FALSE
temporalSpatialTradeOffCapability FALSE
errorCompensation FALSE
h263Options
advancedIntraCodingMode FALSE
deblockingFilterMode FALSE
improvedPBFramesMode FALSE
unlimitedMotionVectors FALSE
fullPictureFreeze FALSE
partialPictureFreezeAndRelease FALSE
resizingPartPicFreezeAndRelease FALSE
fullPictureSnapshot FALSE
partialPictureSnapshot FALSE
videoSegmentTagging FALSE
progressiveRefinement FALSE
dynamicPictureResizingByFour FALSE
dynamicPictureResizingSixteenthPel FALSE
dynamicWarpingHalfPel FALSE
dynamicWarpingSixteenthPel FALSE
independentSegmentDecoding FALSE
slicesInOrder-NonRect FALSE
slicesInOrder-Rect FALSE
slicesNoOrder-NonRect FALSE
slicesNoOrder-Rect FALSE
alternateInterVLCMode FALSE
modifiedQuantizationMode TRUE
reducedResolutionUpdate FALSE
separateVideoBackChannel FALSE
customPictureFormat
maxCustomPictureWidth 160
maxCustomPictureHeight 120
minCustomPictureWidth 160
minCustomPictureHeight 120
mPI
standardMPI 2
pixelAspectInformation pixelAspectCode :
multiplexParameters h2250LogicalChannelParameters :
sessionID 2
mediaControlChannel unicastAddress : iPAddress :
network 'C191C908'H
tsapIdentifier 3233
dynamicRTPPayloadType 96
mediaPacketization rtpPayloadType :
payloadDescriptor rfc-number : 2429
payloadType 96
value MultimediaSystemControlMessage ::= response : openLogicalChannelReject :
cause insufficientBandwidth : NULL
Why I have this message? The gw sends some BRQ to the GK, and the BW for the call goes to 1,5 Mpbs.
When I choose a video call with 384 kpbs I can't not establish the call, even the audio channel.
when is my surprise when I try it with a MCU and the video goes right. What can be the difference? What can I try to see in the debugs?
Thanks everybody
Antonio
irisrios Tue, 03/31/2009 - 08:25
The bandwidth of the video call is selected by dialing a specific GW service. In the GW -> Settings -> Advanced check the "minimum bandwidth for video call" and "default service bandwidth". These should be set for a minimum of 128k. Also GW -> Settings -> Bonding, make sure bonding is enabled.
