how to clear a vpn session on cisco pix 515e
Mar 23rd, 2009
Hi all. I am using cisco pix 515e with ios version 6.3. This pix is configured with alot of site to site vpn with many of my other subsidiaries. Would like to know how i can clear the vpn session of just 1 particular site without affecting vpn sessions of other sites to my cisco pix. I would like to just clear the particular vpn session and not the security association like "clear crypto isakmp". Would like to know this in cases i need a quick fix. Pls advise, thks in advise.
vmoopeung Sun, 03/29/2009 - 13:02
  • Bronze, 100 points or more
To Clear VPN Session :
The "no vpnclient connect" and "vpnclient disconnect" commands disconnect current VPN sessions, but do not prevent initiation of new VPN tunnels.
Note: The "no vpnclient enable" command closes all established VPN tunnels and prevents initiation of new VPN tunnels until you enter a vpnclient enable command.
Remove VPN Client commands:
The "clear vpnclient" command clears the Easy VPN Remote configuration and security policy stored in Flash memory
