UCM / Unity Compatibility with MS Exchange
mparella
Does anyone have a link that explains which verison of UCM/Unity work with Exchange 2003 and 2007? Or specifically does anyone know if UCM 4.2/Unity 4.0 will work with Exch. 2007? Also can you run UCM 7.x/Unity 7.x with Exchange 2003?
Will rate Post.
Thanks!
Jaime Valencia
Exchange 2007 requires Unity 5.x or above
look at the message store section for each version for compatibility
System Requirements for Cisco Unity Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html
System Requirements for Cisco Unity Release 5.0
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html
Cisco Unity 4.2 System Requirements
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/requirements/42cusysreq.html
any other version you're interested can be found here:
Install and Upgrade Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
java
if this helps, please rate
java
Thanks, this definitely helps! It looks like I am OK with running Unity 7.x with Exchange 2003. What about CM? Do you know of any issues running UCM 7.x in Exchange 2003 enviro.?
Thanks again,
Will Rate.
Hi -
I am not aware of any direct relationship between CallManager and Exchange 2003. It's Unity's integration with Exchange that is the key. We are running CUCM 6.1, Unity 4.2 and Exchange 2003; Unity Connection also works with Exchange 2003 for IMAP access using Outlook.
Ginger
Great, Thanks Ginger. I just wanted to make sure if we went up to 7.x versions of CUCM and Unity we would be OK still running Exchange 2003. I found teh Unity article, just nothing formal on CUCM.
Thanks again.
