Static NATing between Private addresses..
Mar 23rd, 2009
i'd like to convert one of our new sites to the network without re-ipping the site to fit our subnets. Can i do some static natting between (existing network) and, which will allow me to route and use the existing network without having to reip the site.
for example map -> etc..
Any help with a sample config or a link to website with info will be appreciated...
Jon Marshall Mon, 03/23/2009 - 10:17
Do you mean static or dynamic. Assuming you meant static then it is relatively trivial eg.
ip nat inside source static
then on your router
int fa0/0
ip address
ip nat inside
int fa0/1
ip nat outside
osmansmalik Mon, 03/23/2009 - 10:40
Actually i am trying to do Static Nat and dynamic as well at the same time. Although it is trivial but i think thats the only option i have.
How will it work if i have a webserver.
will i be able to do port forwarding with static nat which means i will require 2 static nat statements.
One to map to the 10.248.108 ip and another to the WAN ip.
ip nat inside source static tcp 80 80 extendable
Also will i be able to do port overload (PAT) at the same time for clients on accessing the internet.
Thanks for your reply...
