IPS interfaces
Mar 23rd, 2009
on the IDSM-2 module are the interfaces (gi0/2 gi0/7, 8) on the actual IDS module or are they referring to ports on the switch that it is installed on?
marcabal Mon, 03/23/2009 - 12:09
The ports Gi0/7 and Gi0/8 are the actual sensor ports that you configure within the sensor configuration.
Correspondingly there are also switch side ports for each of these 2 sensor ports.
If you are using IOS then gi0/7 is internally connected to "intrusion-detection module data-port 1";
and gi0/8 is internally connected to "intrusion-detection module data-port 2"
So when configuring the IDSM-2 you have to configure data-port 1 and 2 within the switch configuration, as well as configure Gi0/7 and Gi0/8 within the IDSM-2 configuration.
rjaaouan Thu, 03/26/2009 - 02:38
To configure the sensing ports on the IDSM-2 for inline operations, complete the following
Step 1 Log in to the switch.
Step 2 Enter privileged mode:
cat6k> enable
Step 3 Set the native VLAN for the IDSM-2 sensing ports, which are ports 7 and 8:
cat6k (enable)> set vlan 651 3/7
cat6k (enable)> set vlan 652 3/8
Note For this example, the IDSM-2 is installed in slot 3.
Step 4 Clear all VLANs from each IDSM-2 sensing port, except for the native VLAN on
each port:
cat6k (enable)>clear trunk 3/7 1-650,652-4094
cat6k (enable)>clear trunk 3/8 1-651,653-4094
Step 5 Enable bridge protocol data unit (BPDU) spanning tree filtering on the IDSM-2
sensing ports to prevent spanning tree loops:
cat6k (enable)> set spantree bpdu-filter 3/7-8 enable
I hope this is useful
[email protected]
