How do I get back the default "AllDeviceGroup"?
Answered Question
Mar 23rd, 2009
Somehow I deleted the AllDeviceGroup in WAAS 4.1.1d through the Central Manager GUI. What is the best method for restoring that group? I've rebooted the CM, and the other WAAS devices and there is still no AllDeviceGroup.
I didn't think one could delete a default group like that, but I did.
Correct Answer by dstolt about 7 years 11 months ago
Recreate the group (you can name it AllDeviceGroup or anything else) and make it a baseline group. That will have all the devices added to it automatically and all new devices will be added to it as well.
Once it's created, then you can re-add the settings that you had configured in the old one.
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
dstolt Mon, 03/23/2009 - 14:11
Dan
