copy tftp: nvram:startup-config
Mar 23rd, 2009
for 4503-E series and 4506-E series
I want to prepare the configuration offline.
When I tftp the configuration to nvram:
No SSH keys generated
VTP mode and domain not configured
While it gives no error at startup?
Is this not possible?
Leo Laohoo Mon, 03/23/2009 - 15:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Try this ...
1. Copy the configuration from the TFTP to your flash (copy tftp: flash:).
2. Once the copy has been successful, copy the configuration from the flash: to the running-config (copy flash: run).
jandebruyn1976 Mon, 03/23/2009 - 23:56
I'll try it today.
Problem is that the blades are not in there. So it will give errors on the interface configuration.
Possibly when I'll do a write I'll loose these configuration. That's the reason for the copy tftp
It's as preparation for a migration where the chassis and sup will be upgraded while the existing blades will be kept.
justbailey Wed, 03/25/2009 - 13:28
the vtp information is not there because it is not stored in config.text, but rather vlan.dat.
hasmurizal Thu, 04/23/2009 - 00:03
yes correct. you may want to copy vlan.dat before you remove/delete it
