Joe Clarke Mon, 03/23/2009 - 21:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You have two options. One is to temporarily break ACS integration, clean up DCR, then re-enable integration. The other is to temporarily add the missing devices as clients to the ACS server, cleanup DCR, then remove them from DCR.
jhbrubaker Tue, 03/24/2009 - 08:49
The issue is let's say a switch has IP addresses assigned to various ports. Discovery is adding each IP as a device and of course it isn't in ACS. How do you configure discovery not to add those ports?
Joe Clarke Tue, 03/24/2009 - 09:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of LMS are you using?
