CUCM6.1 Cannot Add Line Group
Answered Question
Mar 23rd, 2009
I have 20 Hunt-lists. For just one of the lists, I cannot add a new line group into the list. An error message is as follows: "Update failed. One of the required fields on the page has the same value as an entry that already exists in the database. Please check the corresponding Find List page to verify your entry does not exist". What does this mean?
Thanks.
Correct Answer by tim.giles about 7 years 11 months ago
I think it probably means there is a conflict on the name of the route list with another route list in the database (this is what these type of errors usually mean).
It used to be easy to check things like this in CCM 4 (by checking the tables in SQL) but with 6 it's not quite as easy.
Are there any db issues (check through RTMT)?
Overall Rating: 5 (1 ratings)
Correct Answer
tim.giles Tue, 03/24/2009 - 09:43
Chuan Liu Tue, 03/24/2009 - 12:46
Hi Tim,
I cannot see any conflicts. When I deleted this Hunt-list, I recreated one with the same name It works.
Thanks for your insight.
