Cisco Audit tool !!
Answered Question
Mar 23rd, 2009
  • Gold, 750 points or more
Hi Netpros,
A while ago a colleague mentioned to me about a Cisco tool available for Cisco partners which could be used for auditing Cisco Devices. The tool apparently would generate a report including whether the devices will be reaching end-of-sale end-of-support. I just can't remember what that tools is called nor the link where it can be downloaded. As always .. your help is much appreciated.
Correct Answer by Martin Ermel about 8 years 4 months ago
yes, there is the 'Discovery Tool' (or 'Network Analysis Tool') available for Cisco Partners which you can use after a special online training; you should find more information in the PEC part or the cisco web site. After login, search for 'Discovery Assesment' in the 'Search Learning' field at the top of the page.
Overall Rating: 5 (1 ratings)
Correct Answer
Martin Ermel Tue, 03/24/2009 - 03:59
  • Blue, 1500 points or more
Fernando_Meza Wed, 03/25/2009 - 19:58
Hi mermel,
Great that is exactly the one I was after.
Cheers,
