Cannot direct to voicemail in general greeting / opennning greeting in UC7
Answered Question
Mar 23rd, 2009
In Unity Conneciton 7,
During playing the general greeting or openning greeting, when I enter the extension, it will transfer and ring the extension.
In Unity Connection 1.X or other version, it will direct to the entered extension voicemail.
Where can I change setting, or setting some rule to reach this goal?
Correct Answer by Jaime Valencia about 8 years 4 months ago
go to the user, under transfer settings.
choose send directly to mailbox.
that's not related to version but to the way you configured your system
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 03/24/2009 - 05:15
  • Cisco Employee,
  • Hall of Fame,
    2011
java
russ.kwong Tue, 03/24/2009 - 18:30
Thanks for answer, I find a long but got no ideas..
