Can't locate 1.2.x.DFM.rps file
Mar 24th, 2009
Hi Experts,
I am going to do a remote migration from LMS 2.2 to LMS 3.0 soon. One of the portion is to do DFM3.0 upgrade. However, I can't locate 1.2.x.DFM.rps at NMSROOT\objects\smarts\repos\icf and most probably the DFM3.0 upgrade will fail. Please advise.
Thanks and Regards,
Yi Shyuan
Overall Rating: 5 (2 ratings)
Joe Clarke Tue, 03/24/2009 - 10:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You must following the migration procedures listed at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/data_migration/guide/dmg_win.html#wp1129297 . Have you done all of the backup steps on the 2.2 server, and installed LMS 3.0 on the new serer? Once you do, you can copy the DFM mibration kit from the 3.0 server to the 2.2 server. The rps file you are looking for is simply called DFM.rps (not 1.2.x.DFM.rps). The file will be in NMSROOT/objects/smarts/repos/icf.
jeeyishyuan Wed, 03/25/2009 - 01:05
Hi Joe,
Thanks for the reply. Yea, I have yet to run the migration steps. I have misunderstood that DFM.rps file supposed to be in NMSROOT/objects/smarts/repos/icf before i run the migration steps. Thanks for clearing the doubt.
