PIX IPSEC Help needed
Mar 24th, 2009
can i give a static gate way to Ipsec/l2tp adopter, we deployed the tunnel its working fine , but one specific application required Gateway ip address should be the standard , we are working on XP
PPP adapter jj:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. .. . : 10.133.3.202
Subnet Mask . . : 255.255.255.255
Default Gateway .: 10.133.3.202
DNS Servers . . : 10.133.3.3
Primary WINS Server . : 10.133.3.3
i want change the default Gate insted of 10.133.3.202 / 10.133.3.145
plz help me how to do it ?
andrew.prince@m... Tue, 03/24/2009 - 03:04
  • Green, 3000 points or more
You cannot change the default gateway IP address, as the traffic needs to enter the virtual adapter to be encrypted and sent over the IPSEC/L2TP.
rsjavahar Wed, 03/25/2009 - 01:23
Is there any other option like routing or ACL or some thing to make 10.133.3.146 to act as a gate way for the vpn clients
andrew.prince@m... Wed, 03/25/2009 - 01:30
No - the gateway on the client MUST be the virtual adapter that the traffic is encrypted thru on the local machine, that is the only way it works.
