Load Balacing for FWSM
Answered Question
Mar 24th, 2009
I'm implementing a data center with an Aggregation layer equiped with FWSM-1 which cannot support active/active failover.
I'm thinking about multi-context to manually divide traffic into the two CAT6500.
Any comment or suggestion ?
Correct Answer by Jon Marshall about 8 years 1 month ago
Omar
You did ask for comments after all :-).
You said in your initial post that you could not use active/active but what you describe in terms of failover in your scenario is active/active, see this link -
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/fail_f.html#wp1052847
If you choose to go active/standby you cannot have FWSM1 active for one context and standby for another.
Jon
Overall Rating: 5 (2 ratings)
Jon Marshall Wed, 04/01/2009 - 13:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Omar
Not sure i fully understand. If you run active/stanby then multi-context will not allow you to have different FWSM's active and standby. In an active/standby config the active firewall is active for all contexts and the standby is stanby for all contexts.
Only active/active will allow you to use both FWSM's at the same time.
Jon
omar.elmohri Thu, 04/02/2009 - 05:30
And you want to say that we cannot create more than one failover group when using active/standby ?
Jon Marshall Thu, 04/02/2009 - 07:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Omar
My understanding is that even with active/active both FWSM's are never active for the same context so yes unless you use active/active one FWSM is active for all contexts and one is standby.
Jon
Correct Answer
Jon Marshall Thu, 04/02/2009 - 11:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Omar
Jon
