Deploy UC520 in a 2003 network
Answered Question
Mar 24th, 2009
I've configured the UC520 and it works like a charm standalone. But now I wan't to deploy it into our network where a windows 2003 server acts dhcp. I've read countless of forum threads on this but I'm not certain how to disable the dhcp in the UC and use the server 2003 as dhcp.
I want the the data (vlan 1) to be assigned IP from the windows dhcp (192.168.100.1XX) and the phone (vlan 100) to be assigned by the UC.
To spice up the problem, I also wan't the IP Communicator to work on users computers.
Thanks!
Correct Answer by Nicholas Matthews about 8 years 2 days ago
no ip dhcp pool
interface
ip helper-address
Overall Rating: 4 (1 ratings)
Nicholas Matthews Tue, 03/24/2009 - 04:29
  • Red, 2250 points or more
There are DHCP pools, you would need to disable those.
"no ip dhcp pool phones" etc.
If the DHCP server isn't in the same subnet as the devices it is servicing, you would need the ip helper-address on the layer 3 interface for each VLAN.
hth,
nick
m.junghage Tue, 03/24/2009 - 04:55
Thanks!
Since I'm fairly new to this I'd appriciate if you could write down the cli commands I need to do this?
Thanks!
Correct Answer
Nicholas Matthews Tue, 03/24/2009 - 12:22
no ip dhcp pool
interface
ip helper-address
