RME config archive issue with 4507-R
Mar 24th, 2009
we are getting same error after upgarding MDF 1.13 and Cat4000IOS.RME40.v3-0.readme.Zip.device package for RME.but still the same error
10.112.200.3 PRIMARY RUNNING Feb 26 2009 20:29:31 CM0056 Config fetch failed for 10.112.200.3 Cause: CM0204 Could not create DeviceContext for 837 Cause: CM0206 Could not get the config transport implementation for 10.112.200.3 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
RME version 4.0.5
Running IOS on both the switchws is cat4500-ipbasek9-mz.122-40.SG.bin
also both these devices showing in RME>DEVICE>SELECTOR LIST> ? SIGN.
Plse help me out this is on another server.
vaibhav-g Tue, 03/24/2009 - 06:09
Plse find IC_server.log and snapshot for the RME>Device>device selector list where it is showing ? mark sign.
plse plse help me out.
Regrads
Vaibhav
Joe Clarke Tue, 03/24/2009 - 13:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You do not have a package to support this switch. If this is a 4507R-E switch, then you need to upgrade to RME 4.0.6 before you can install the Cat4000IOS package which adds support for this switch. If this is a 4507-R (without the -E) it is supported in RME 4.0.5, but you need to upgrade your Cat4000IOS.zip package. The latest RME 4.0.5 Cat4000IOS package is 3.0.
As I have said to you before, it looks like your RME package repository is damaged. In order to fix this so you can install new packages, you need to open a TAC service request.
Once your package issues are sorted out, you will be able to properly manage this switch in RME.
vaibhav-g Wed, 03/25/2009 - 10:29
Hi Clark
thanks a lot it is 4507R-E so we need to upgarde 4.0.6 than we will update CAT4000IOS...once we will done the same let you know the resull
Vaibhav
