Router 7613 boot problem
Mar 24th, 2009
  • Community Spotlight Award,
    Spanish Member's Choice: May 2016
Hi guys, I have a router 7613 with a supervisor 720. each time I reboot it I have the follow:
*** --- SHUTDOWN NOW ---
Mar 24 09:55:16: %SYS-SP-5-RELOAD: Reload requested
Mar 24 09:55:16: %OIR-SP-6-CONSOLE: Changing console ownership to switch process
or
Mar 24 09:55:16: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ens
ure console debugging output.
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
rommon 1 >
I am using only one supervisor the standby blade is not inserted.
the onfiguration register is 0x2102
What the problem could will be?
Thanks!
a.alekseev Tue, 03/24/2009 - 09:04
  • Gold, 750 points or more
in rommon set correct BOOT variable
after that enter command "sync"
It should fix your problem.
Leonardo A Pena... Tue, 03/24/2009 - 12:24
Hi this is what I have:
router#show bootvar
BOOT variable = ,1;sup-bootdisk:s72033-advipservicesk9_wan-mz.122-18.SXF15a.bin,
1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is not present.
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
CONFIG_FILE=bootflash:switch.cfg
?=0
BOOT=bootdisk:,1;
SLOTCACHE=cards 1=104([email protected],[email protected]),2=104([email protected],[email protected]),3=104([email protected],[email protected]),4
=104([email protected],-);
CRASHINFO=bootflash:crashinfo_20090227-190703
TYFIB_BLOCK_ALLOC=
BSI=0
ACL_DENY=0
PF_REDUN_CRASH_COUNT=0
How can I fix it? can yo give a example please?
Thnks
Yudong Wu Tue, 03/24/2009 - 13:33
It looks like you have an extra BOOT variable " ,1".
try to remove all boot statement in your current config and then add the one you need back. After that, check the output of "show bootvar".
a.alekseev Tue, 03/24/2009 - 23:59
in rommon do the following
BOOT=sup-bootdisk:s72033-advipservicesk9_wan-mz.122-18.SXF15a.bin
sync
and check "boot system" in the configuration
