AP521 HTTP access
Leo Laohoo Tue, 03/24/2009 - 14:12
I'm not familiar with this type of WLC, however, with it's bigger brothers (WLC 2000/2100/4400/WiSM), you can no longer access the HTTP of the LAP because it's exactly serving it's true purpose. All configuration and provisioning are being centralised on the WLC.
yes, but I could not find that configration
(Cisco Controller) >?
clear Clear selected configuration elements.
config Configure switch options and settings.
debug Manages system debug options.
help Help
linktest Perform a link test to a specified MAC address.
logout Exit this session. Any unsaved changes are lost.
ping Send ICMP echo packets to a specified IP address.
mping Send Mobility echo packets to a specified mobility peer IP address.
eping Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
reset Reset options.
save Save switch configurations.
show Display switch options and settings.
test Test trigger commands
(Cisco Controller) >config ?
advanced Advanced Configuration.
(Cisco Controller) >config advanced ?
802.11a 802.11a parameters.
802.11b 802.11b parameters.
client-handoff Auto handoff the clients on excessive retires.
dot11-padding Configure over-the-air frame padding
eap EAP (Extensible Authentication Protocol) Settings
macfiltering Configure advanced macfilter settings.
max-1x-sessions Maximum 802.1x session initiation per AP at a time.
probe-limit Limit number of probes sent to switch per AP slot per client in a given interval.
rate Enable/Disable switch control path rate limiting.
statistics Enable/Disable switch port statistics.
timers Configures system timers.
