DNS Server on router
Answered Question
Mar 24th, 2009
Hi all...Please can someone help me!
OK here is the issue, I have just set up an 837 at home in place of my bband wireless router. I managed to get the ADSL configured correctly and NAT etc is all working fine, however I could not figure how to set up the DNS.
Previously the old Netgear router i replaced with this used to do DNS locally for me as I dont have a DNS server set up at home...
Now in the config I have pointed the router towards 4.2.2.1 and 4.2.2.2 for DNS and also set DHCP to automatically assign the same DNS server to clients (as otherwise they cant browse the net!)
I thought the clients could use the router (10.10.10.1) as their DNS server but I cant seem to get that working...
n e ideas?
Correct Answer by John Blakley about 7 years 9 months ago
I believe you'll need to enter a domain name for your router:
ip domain name
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Tue, 03/24/2009 - 10:32
ip domain name
HTH,
John
Urfan Khaliq Tue, 03/24/2009 - 10:38
Thanks john but I dont have a domain set up at home, just a couple of home PC's....
John Blakley Tue, 03/24/2009 - 10:40
It's fine :)
ip domain name home-router.info
This isn't propagated anywhere.
HTH,
John
Urfan Khaliq Tue, 03/24/2009 - 10:42
would i then be able to set the router (10.10.10.1) as my DNS server on my host pc's?
John Blakley Tue, 03/24/2009 - 10:44
Should. It looked like you had everything else in the config.
You *may* need:
ip domain-lookup
as well.
HTH,
John
