ASA Cut Through Proxy Authentication
Mar 24th, 2009
Hello Everyone,
I have configured the ASA's for users to authenticate directly at the firewall via http/https. I am looking for a solution with Cut Through Proxy Authentication to do the following:
1. When a user closes the browser the cached authentication session is not terminated/cleared. I need a way to enable this functionality.
2. When a user clicks the logoff button, the user's cached authentication session is terminated/cleared. However, the current connection(s) associated with the source address are not cleared/terminated. Is there any way to clear/terminate all connections from the source address after they have either logged out or if the absolute timeout value expires?
3. Is there a way to clear the user's authenticated session if all connections from that source host clear/terminate?
I will look forward to your responses.
Thanks & regards,
