Cannot configure Serial Interface on 1721 router
d-leonard
Hello, I'm configuring a Series 1700 router for our T1 Frame Relay. The configuration is going well until the router will not let me set the Serial Interface.
Router<config>#interface serial0
Results in:
% Invalid Input detected at '^' marker.
The ^ points to the S in Serial.
Sorry for the simplicity of my question. I'm basically a hardware tech thrown into the Network Admin spot. Any answers appreciated. Thanks for your time.
21 Replies 21
lamav
Level 8
Level 8
At the config prompt, type "interface ?" and press enter. Tell us what choices you see.
Thanks for the reply,
Choices:
Async
BRI
BVI
CTunnel
Dialer
FastEthernet
Group-Async
Group-Serial
Lex
Loopback
MFR
Multilink
Null
Tunnel
Vif
Virtual-Template
Virtual- TokenRing
range
Hi:
As you can see, "serial" is not one of your choices. The only physical inetrface it offers is the fastethernet.
Can you do a "sh mod" or " sh hard"?
Also, do a "sh run" and post that, too.
John Blakley
Can you post "show ver"? What time of WIC do you have in your router?
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks for the reply.
C1700 Software
Ver. 12.2<5.5>T
WIC 1DSU t1
Check this link out!
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a0080093d70.shtml
Note: Cisco 1701, 1710, 1711, and 1712 are fixed-configuration routers and do not support the WIC-1DSU-T1 or WIC-1DSU-T1-V2. Also, the Cisco 1750 does not support this WIC
HTH,
Toshi
Thank you for your reply, however, we have 4 other 1700's utilizing this WIC.
Hi:
Sorry for the delay, thanks for your reply. Here's the info:
burke-1721#sh hard
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
Synched to technology version 12.2(5.4)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 11-Apr-02 21:54 by ealyon
Image text-base: 0x80008124, data-base: 0x807976DC
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SO
FTWARE (fc1)
burke-1721 uptime is 48 minutes
System image file is "flash:c1700-y-mz.122-4.YA2.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 29492K/3276K bytes of memor
y.
Processor board ID FOC070802CJ (1339366764), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x142
urke-1721#sh modemcap
default
codex_3260
usr_courier
usr_sportster
hayes_optima
global_village
viva
telebit_t3000
microcom_hdms
microcom_server
nec_v34
nec_v110
nec_piafs
cisco_v110
microcom_mimic
mica
nextport
Building configuration...
Current configuration : 612 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname burke-1721
enable secret 5 $1$VF07$ucOJaHE5R2AqJjqJor0by1
enable password
ip subnet-zero
isdn switch-type basic-5ess
interface BRI0
no ip address
shutdown
interface FastEthernet0
ip address xxx.xxx.xxx.xxx 255.255.255.0
speed auto
full-duplex
ip classless
no ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
line aux 0
line vty 0 4
password p.
login
no scheduler allocate
end
Well, Are they the same model? Are they using the same IOS as well?
Yes they are the same models and all have the same IOS. Thanks.
FTWARE (fc1)
burke-1721 uptime is 1 hour, 32 minutes
y.
Bridging software.
You didnt post the "sh run" but anyway, its obvious that the system is only recognizing one physical interface, and thats the FastEthernet interface.
