2851 Uploading files to flash SLOW
Answered Question
Mar 24th, 2009
upgrading a 2851 and adding Callmanager Express files to a brand new 2851. I've tried various connections between the router and my laptop (Gig NIC) to transfer files via TFTP and it is unbelievably slow. I've tried different TFTP servers, directly connecting to the router (crossover) ... all to no avail. Am I missing something? Why is it transferring so slow? I have no problems whatsoever with all other connections from my laptop. Help.
Correct Answer by Joseph W. Doherty about 8 years 2 months ago
See attachment.
[edit]
Thank you for the rating, but don't deserve it, since updating the bootstrap was Leo's suggestion.
[edit2]
BTW, I believe I recall on other 2800s, a bootstrap update, to take, will immediately reload the box. Also, procedure/command is different vs. normal IOS.
NB: Don't be surprised if the doesn't fix your issue since flash RAM/ROM isn't usually considered DRAM. But let us know whether it makes a difference or not.
Correct Answer by Leo Laohoo about 8 years 2 months ago
Try upgrading the Bootstrap and compare the result.
Overall Rating: 5 (2 ratings)
Yudong Wu Tue, 03/24/2009 - 13:29
  • Gold, 750 points or more
What existing code is?
It might be a bug.
Can you try FTP to see if it is different?
Brian Carscadden Tue, 03/24/2009 - 13:38
It was slow with the shipping version ... don't recall what that was. Then I upgraded to 12.4.22T ... and it's just as slow.
Leo Laohoo Tue, 03/24/2009 - 13:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Look at your processor and see if the CPU level has gone up (sh processor cpu history).
Brian Carscadden Tue, 03/24/2009 - 13:48
Yep ... pegging at 100% What can I do?
99999 999999999999999 9999999999999999999 9999999
111119999911199999999999999911119999999999999999999119999999
100 *###* *#######*#####* *#######*#####**##* *#*##**
90 *###* *#############* *#############**##* *#*##**
80 *###* *#############* *#############**##* *#*##**
70 *###* ##############* *#################* *####*#
60 *###* ##############* *#################* *####*#
50 ##### ##############* *################## *######
40 ##### ##############* *################## *######
30 ##### ##############* ################### #######
20 ##### ############### ################### #######
10 ##### ############### ################### #######
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
Joseph W. Doherty Tue, 03/24/2009 - 15:38
The issue you might be bumping into is, not all flash hardware supports fast recording. For example, copy an IOS image within the same device (i.e. not to/from external device) and it likely will perform just about the same.
On the issue of high CPU, that's not unusual. Cisco appears to invest their IOS development efforts in supporting the device's primary purpose, processing transit traffic. Things like upgrading a flash, as quickly as possible, likely isn't high on their priority list.
PS:
Another common reason for slow flash upgrades, if you use TFTP with high latency, it runs slow (which doesn't seem to be an issue in your case). FTP or RCP will copy much faster if latency is an issue.
Brian Carscadden Wed, 03/25/2009 - 11:00
When I initially went to upgrade the IOS from the shipped version to a newer version it was VERY slow, and finally bombed. When I rebooted it went into ROMMON mode and I used TFTPDNLD and it went FAST. After the router rebooted I resumed with copying CME files up to the router, but it went back to being reallly slow. I doubt it's a latency issue as this is a new isolated "lab" setup; the only two enpoints are the router and my laptop.
Leo Laohoo Tue, 03/24/2009 - 17:01
  • Hall of Fame,
    2017 LAN, Wireless
In light of Joseph's comment, what is the version of the Bootstrap?
C2800NM_RM2.srec.124-13r.T6 is a bootstrap for "DRAM access optimization".
Correct Answer
Leo Laohoo Wed, 03/25/2009 - 14:52
  • Hall of Fame,
    2017 LAN, Wireless
Brian Carscadden Thu, 03/26/2009 - 06:25
Where do you download the Bootstrap software from? I couldn't find it in the downloads section....
Correct Answer
Joseph W. Doherty Thu, 03/26/2009 - 06:32
See attachment.
[edit]
[edit2]
Brian Carscadden Thu, 03/26/2009 - 07:27
Of Course - fair enough, thanks Leo!
Ok ... next question. How do I upgrade a Bootstrap image. I can't find the doc on CCO on how to do this....
Brian Carscadden Thu, 03/26/2009 - 08:21
Thanks guys that did it. Unfortunately the new ROMMON upgrade didn't speed up file transfers to the box. I'm going to try a few more things.
sanmigueelbeer Thu, 03/26/2009 - 15:20
Thanks for the rating. What version of bootstrap did you upgrade this to?
Leo Laohoo Thu, 03/26/2009 - 15:31
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating. Can you tell me what Bootstrap version did you upgrade to?
Bootstrap 12.4(13r).T5 can be found here:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=12.4%2813r%29T5&mdfid=279316777&sftType=IOS+ROMMON+Software&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+2801+Integrated+Services+Router&treeMdfId=268437899&treeName=Routers&modifmdfid=&imname=&hybrid=Y&imst=N&lr=Y
It's described as "Enhancement for device access in certain Cisco routers." and released on 06-Oct-2008.
transnetcorp Fri, 03/27/2009 - 05:08
Actually, it was this one:
Release Date: 06/Oct/2008
C2800 ROMMON Upgrade: DRAM access optimization
Size: 1585.15 KB (1623191 bytes)
Solved the problems I was having 100%.
Brian
TransNet
Leo Laohoo Fri, 03/27/2009 - 17:30
  • Hall of Fame,
    2017 LAN, Wireless
So this fixed your problem Brian?
Brian Carscadden Mon, 03/30/2009 - 02:03
"Solved the problems I was having 100%."
Indeed it did. Thanks for your part in helping out.
(incidentally, I'm an EDS alumnus, 1989-1994, so a kind regards in that respect as well...)
Brian
Leo Laohoo Mon, 03/30/2009 - 02:56
  • Hall of Fame,
    2017 LAN, Wireless
Hi Brian,
Glad that we were able to provide assistance and support to your issue.
NOTE: Left EDS last 30 December 2008. :-)
