Blocking-Pattern Route List
Hythim Ali El Hadad Tue, 03/24/2009 - 13:42
  • Silver, 250 points or more
I understand that you need to block a pattern from your users
It is only by creating this pattern and mark the check box [block this pattern]
wish this be helpful
Jaime Valencia Tue, 03/24/2009 - 14:54
  • Cisco Employee,
  • Hall of Fame,
    2011
a RL or a gateway are mandatory elements when creating a route pattern.
you cannot only create it with the pattern and block this pattern
dummy/real RL/GW are necessary to be selected to create the route pattern and block calls
java
if this helps, please rate
