unable to allocate ike sa
Mar 24th, 2009
cat 6500 with IPSec VPN module. VTI is configured, but debugs show that it is unable to allocate ike sa.
Have changed the key, removed the keyring and just used a global type isakmp key. no change.
crypto engine mode vrf
crypto keyring key1
  pre-shared-key address 1.1.1.1 key <key>
crypto isakmp policy 1
  encr aes
  hash sha
  authentication pre-share
crypto isakmp profile isa_prof
  keyring key1
  match identity address 1.1.1.1 255.255.255.255
crypto ipsec transform-set proposal esp-aes esp-sha-hmac
crypto ipsec profile vpnprof
 set transform-set proposal
 set isakmp-profile isa_prof
int Tunnel0
 ip vrf forwarding inside
 ip addr 10.10.10.0 255.255.255.254
 ip summary-address 3 10.0.0.0 255.0.0.0 255
 tunnel source Loopback1
 tunnel destination 1.1.1.1
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile vpnprof
 crypto engine slot 3/0 inside
int Loopback1
 ip addr 2.2.2.2 255.255.255.255
 crypto engine slot 3/0 outside
bwilmoth Tue, 03/31/2009 - 08:02
  • Silver, 250 points or more
Do you have IOS version of 12.2.18SXF? If not then I'd give that a try.
