03-24-2009 02:16 PM - edited 03-15-2019 05:03 PM
Are there any formulas anyone uses for determining WAN circuits for locations that will be utilizing VoIP. We currently always request 100mb circuits if the circuit will have ip phones, but I'd like a way to determine the "right" sized circuit.
Thanks in advance.
Solved! Go to Solution.
03-24-2009 02:46 PM
I think this is what you're looking for:
http://tools.cisco.com/Support/VBC/do/CodecCalc1.do
Hope it helps.
-nick
03-24-2009 02:46 PM
Hope it helps.
-nick
03-25-2009 05:02 AM
Thanks for the helpful link Nick.
/rls
