Sizing LMS server
Hi, I'm in the process of specifying hardware to run CiscoWorks LMS 3.1, and have noted that for our size network (<5000 managed nodes) the recommendation is for a quad CPU system.
The question is: for the purposes of this sizing, are discrete cores considered CPUs, or should I be counting sockets?
(Obviously a single socket, quad core system is substantially cheaper.)
Joe Clarke Tue, 03/24/2009 - 17:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Discrete cores ARE considered CPUs. Hyperthreading is NOT. A quad core, single chip system will be fine provided it meets minimum RAM and disk requirements.
