The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
헗헲헹혁헮 헔헶헿헹헶헻헲's phone number to call and talk with a live 헿헲헽헿헲혀헲헻혁헮혁헶혃헲 fast is ퟏ-ퟖퟖퟖ-ퟖퟐퟗ-ퟏퟏퟕퟎ // ퟏ-ퟖퟖퟖ-ퟖퟐퟗ-ퟏퟏퟕퟎ. Select your connection language upon call and choose the IVR option that best suits your query by looking through the ones that are gen...
Hello all,on one of my SNS-3755-K9 Applience can not open vkvm.after clicking on start and accepting "Load KVM Certifivate" i recieve a blank new Page and 3 Errors (see Screen Shots)Please take a look at this Problem as sonn as possible. Reset Facto...
Hello,I have a switch I am unable get a prompt on the console port.I can SSH to it, and have confirmed that the baud rate and stop bits are correct from the console switch. There are two other switches that I can console to.The differences are that t...
Main issue: The Webex Room Kit Mini is pulling an IP address, but the TelePresence Touch unit, which is connected to the Room Kit's dedicated Touch port (which I assume acts at least as a pass-through network port) is not (it's getting a 169.254.x.x...
Hi, I'm deploying config from CSM but received error : An error response from the device prevented successful completion of this operation. The device provided the following description: enable password ****** pbkdf2 PBKDF2 hashed enable password ***...
Is there something different about configuring SSH on a 9407 with a C9400-SUP-1? Currently there's no configuration on the device except for an IP address on the management port and ssh. I've gone through the same procedures we've always used and v...
Team,We have a new Cisco Firepower 1120 just configured with basic configuration.After the admin user I added another user with the "configure user add" command.This new user can SSH to the device but cannot SSL.Further, I want to ensure that this ne...
Hello,i was successfully deploying Nac configuration on all my switches when i encountered i problem with the new authentication display config-mode on a WS-C2960X-48LPS-L 15.2(7)E4:SwitchplanA#authentication display config-modeCurrent configuration...
Hi all I'm setting up a CISCO LAB to keep me busy in my retirement. My Current network consists of a TP-Link Deco mesh network which works well for my IOT, PCs and internet access. I just got hold of a Cisco 1941 router with a EHWIC D8SGP module. ...
Hello,I am still considering wheter to deploy Catalyst1000 or CBS350 switch at our small office(15-25 devices).Switch have to be configured with multiple SVIs and DHCP server pools for each + few static routes.I would like to secure MGMT access to th...
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
Hi, I want to install the Rest API package for ASA Firewalls, but I always get the error: ciscoasa(config)# rest-api image disk1:/asa-restapi-132200-lfbff-k8.SPAlina_cs is not running on platform that supports image signingOpen message queue fail: Re...
