03-24-2009 05:33 PM - edited 03-06-2019 04:47 AM
I am looking to deploy implement VRF zones on a Cisco 3750/3550. Is there a limit on the number of zones the switch can implement? If so what is the maximum number of zones?
Solved! Go to Solution.
03-25-2009 02:13 AM
Hello Mun,
a C6500 can handle 1000 VRFs but a C3750/C3550 have much lower limits in the range 26 for c3750 and may be only 8 for C3550.
Hope to help
Giuseppe
03-25-2009 08:39 PM
3750 info can be found at:
As Giuseppe said 26
However, the 3550's figure is 7:
HTH,
__
Edison.
03-25-2009 02:13 AM
Hello Mun,
Hope to help
Giuseppe
03-25-2009 06:50 PM
Hi Giuseppe,
Thanks for the info. May I know where you get those figures.
Alan
03-25-2009 08:39 PM
As Giuseppe said 26
HTH,
__
Edison.
