ASA authentication
Mar 24th, 2009
Hi all,
How can i configure my ASA to authenticate only once to ACS. Cause i saw in my logs whenever i attempted to login to ADSM then ASA will authenticate with ACS a number of times.
Thanks alot
leo_zidane Thu, 03/26/2009 - 00:23
Thanks for the reply u are the one that respond to me.
So does that mean that i cannot use RSA tokens to authenticate my ASA via ASDM?
Cause I login to ASA via ACS DB it will has several authentication login and this will pose a problem as RSA token has a unique passcode every time.
leo_zidane Thu, 03/26/2009 - 03:34
Actually SSH to ASA is workable. cause it only need to authenticate one time. But for ASA via ASDM it need to authenticate a few times causing RSA token authentication to fail.
Is there any expert can help on this?
leo_zidane Thu, 03/26/2009 - 18:41
Can any cisco support engineer give advise on this?
How come RSA token via radius server is not supported by ASA using ASDM?
kzhen Mon, 04/06/2009 - 06:59
I have an same issue. Did you solve the problem? If you do, can you share with me?
