CM4.2.3sr4b and SIP
Mar 24th, 2009
  • Bronze, 100 points or more
I want to setup SIP to provider and below is the config to the provider.
I have CM4.2.3sr4b. What do I configure on my end. I have a MGCP GW onsite runnin
c3825-adventerprisek9_ivs-mz.124-23.bin
dial-peer voice XXX voip
description SIP Outbound
session protocol sipv2
session target ipv4:192.168.X.Y
dtmf-relay rtp-nte
fax protocol pass-through g711ulaw
codec g711ulaw
no vad
Nicholas Matthews Wed, 03/25/2009 - 08:21
  • Red, 2250 points or more
There are two options:
1) Set up SIP on your gateway. Then, set up either H323 or SIP to CUCM. This is CUBE.
2) Set up the SIP trunk directly on your CCM. Since you're on CCM 4.2, this isn't recommended since SIP support on that version isn't very good.
MGCP is a protocol that allows CCM to control analog endpoints. In the case of a SIP provider, you need either SIP or H323 to send calls to the gateway since there are no analog endpoint involved in the topology.
hth,
nick
aamercado Wed, 03/25/2009 - 20:18
Can your provide a sample on gw piece?
Is it better better to use sip or h323 to CUCM?
Sounds like with 4.2, it is better to use h323 btwn CUCM and GW and from SIP btwn GW and provider.
TIA
bsugamele1 Thu, 03/26/2009 - 12:18
I'm running CUCM 4.2(3)sr4b and have implemented a SIP trunk to a 2811 CUBE router to connect our system to another non Cisco platform. It works flawlessly. Just make sure you build your dial peers and dial plan correctly and you won't have any issues.
