linksys rv 082
Mar 24th, 2009
Hi every one,
I have problem in connecting my vpn clients
I have Linksys RV 082 vpn router , i have enabled the PPTP, L2TP AND IPSEC
1. I am able to connect through pptp connection, in this the ip address allocating through dhcp server
    but i can't allocate on my own , even i disabled the dhcp server it works for two connection after two connection it says
    735 ip address is blocked
2. I am able to connect using quick vpn succesfully , but no ipaddress is allocating for this server
  becos of this i can able to ping the vpn router rest any other computer i can't use
   same way local computer also unable to access the remote computer
this will be great if any bosy helps mee
thanks
john
Steven DiStefano Wed, 03/25/2009 - 07:40
On this page:
http://www.cisco.com/en/US/products/ps9926/index.html
You will find excellent new documentation on using QVPN on Cisco Small Business Routers.
Including installing QVPN:
http://www.cisco.com/en/US/products/ps9923/products_qanda_item09186a0080...
And the router configuration:
Make sure you have the latest version client (1.2.11) and the latest FW on the router.
