Cisco 1200 Crashed
Mar 25th, 2009
Hello All
My working AP1200 crashed in the bottom I am seeing the lights for radioand ethernet red and status is light purple on the other hand in console mode
I am just seeing
ap:
and possible commands are
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
clear_ether -- clear ethernet port statistics
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
dump_save_regs -- dump saved regs in OCM
etest -- test emac driver code
ether_init -- initialize ethernet port
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
init_pci -- initialize pci bridge
led_test -- cycle led patterns
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
-- MORE --
reset_gpio -- reset gpio
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_baud -- set baud rates
set_gpio -- set gpio
set_sleep -- Pause (sleep) for a specified number of seconds
show_ether -- show ethernet port statistics
show_pci -- show pci setting
switch status -- report push button switch status
tar -- extract or listing a tar file
test ram -- read at address
tftp_init -- Initialize tftp file system
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
But some of them are not working for example Boot
ap: boot
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
ap:
One more thing during reset
The system is unable to boot automatically because there
are no bootable files to boot.
Looks like no IOS on it.I would also like to ask how to put IOS back into the AP
Any idea how to recover it ?
Ersin
jeff.kish Wed, 03/25/2009 - 06:37
  • Silver, 250 points or more
Hi Ersin,
I actually just went through this process myself. First, run the "dir flash:" command to see if you have anything in flash (this may require the "flash_init" command first). If you have an IOS copy, it may be corrupt and you should delete it before proceeding. If not, proceed away!
Next, run the "ether_init" and "tftp_init" commands. This turns on the Ethernet interface and enables TFTP. You'll next want to use the "set" command to change the IP address. You can change it to anything, really, as long as it can access a TFTP server on your network, or maybe access your PC directly via a cross-over cable.
Next, run the "tar tftp://TFTP_SERVER/FILENAME" command (I think this is right, but you might need to play with the syntax a bit). This will unzip the IOS file directly to flash. This is usually required because the 1200 doesn't have enough flash to store the tar file and unzip it at the same time.
I hope this helps! Let me know if I forgot anything, or if this doesn't work for any reason.
Jeff
ergonullu Wed, 03/25/2009 - 06:52
Bad news...
I copied the file and extract it now
executing...
Xmodem file system is available.
flashfs[0]: 151 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 4973056
flashfs[0]: Bytes available: 11025920
flashfs[0]: flashfs fsck took 28 seconds.
Base ethernet MAC Address: 00:1d:a1:ff:fb:a2
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1200-k9w7-mx.123-8.JEA2/c1200-k9w7-mx.123-8.JEA2"...###########
File "flash:/c1200-k9w7-mx.123-8.JEA2/c1200-k9w7-mx.123-8.JEA2" uncompressed and
installed, entry point: 0x3000
executing...
and it hangsç.Break sequence is not workinmg for ap:...how could I get in the ap: during the boot by break
Ersin
Leo Laohoo Wed, 03/25/2009 - 15:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Ersin,
I think it's time for you to RMA this unit.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
