jeff.kish Wed, 03/25/2009 - 06:51
  • Silver, 250 points or more
No, it unfortunately can't handle PDFs.
If you want a labor-intensive way of getting better images, this is what I do: I zoom in pretty far on my PDF, then grab a screenshot (Use ALT-PrintScreen). Then go into MS Paint or some similar program and paste in the small section you copied. Then go back to your PDF, take another screenshot, and repeat until you're completed your image.
MS Paint is awful for JPG, though, so I'd either save it as a BMP and use another program to compress into JPG, or just use another program to begin with.
Not sure if that helps or not :/
Jeff
