ASA logs
Mar 25th, 2009
I am facing issue with accessing firewall syslog files.the size is around 2GB.It says i need to open it with another editor rather than notepad.I tried with wordpad but it hungsup.
Any suggestions on this.Also i have heard that the logs are stored by date( a day each) in seperate log files.How do i enable that?
Thanks in advance!
Overall Rating: 4 (2 ratings)
cisco24x7 Wed, 03/25/2009 - 05:20
The best syslog would be syslog-ng which will give the ability to rotate the log file at certain size, date, etc... If you have multiple firewalls, syslog-ng can store logs in separate files.
syslog-ng comes free with most Linux distribution
Collin Clark Wed, 03/25/2009 - 06:02
Any application will have trouble opening a 2GB log file. Try using a syslog server like RSyslog ( it also has a web front-end so you can view a log and filter the results. If you want to have each device as a separate log file, you will need to configure it in your conf file on your server.
Hope that helps.
suthomas1 Wed, 03/25/2009 - 06:49
ok..not each device as seperate log file...same device but it would give seperate log files for each there a way on this..
lorih.fns Wed, 03/25/2009 - 13:25
For viewing large syslog files, or any large text file for that matter, I like UltraEdit. UltraEdit can handle and edit files in excess of 4 gigabytes.
It's fairly inexpensive and has tons of great attributes that make it worth every penny!!!
Collin Clark Wed, 03/25/2009 - 13:31
UltraEdit is the best text editor out there, however even it has problems with a 2GB file (probably more the PC than the app). I also use GSplit to take the file and break it up. Excel and it's Auto Filter option are very useful as well.
cisco24x7 Wed, 03/25/2009 - 17:06
Why would anyone want to view a >2GB file is beyond me. Perl, MySQL, awk and grep were developed for extracting from large file like this.
suthomas1 Thu, 03/26/2009 - 19:39
thanks for the inputs..another query.
how do you stop the logs being continually generated/updated to the particular text file inside the system logs from the device.
I am trying to delete the log file...but it says something else is using this,probably the firewall is generating logs into this.
Any ideas on do we stop this for i need to configure anything on firewall for this?
Collin Clark Mon, 03/30/2009 - 06:19
You either have to stop syslog from the firewall, stop it on the server or copy the log file and read the copied file.
