How long are login credentials cached for?
Mar 25th, 2009
Our wireless setup is LWAPP with 4404 authenticating to an ACS using 802.1x. After connecting the wireless network and providing a username and password, how long is that information cached?
For example, I noticed if you turn off the laptop and then turn it on again, it automatically connects to the wireless. Is there a way to force re-logon after a certain amount of time?
Seth
paulpoon Fri, 03/27/2009 - 08:33
You can use session timeouts on the WLC, under WLAN, advanced.
Session Timeout (secs) - Set the maximum time for a client session before requiring reauthorization. Default = 1800 seconds.
Trending Topics - Security & Network
